automatic ls into a auto eg.
Old Jun 7, 2009 | 02:07 PM
jdmdikk's Avatar
Default automatic ls into a auto eg.
my friend has a 92 civic auto and he has a auto 95 ls swap into the car..car runs and drives but does not shift on its own ,,he has to shift manually in order for the car to change gears..any i dea on why its not changing gears on its own??are we missing anything?any help will be nice..thanx
Old Jun 7, 2009 | 02:10 PM
98civdx's Avatar
Master Detailer
Default Re: automatic ls into a auto eg.
the way an b series auto shifts is toalty different then the civic.
did you hook the trannys computer up right?
Old Jun 7, 2009 | 02:12 PM
jdmdikk's Avatar
what computer on the tranny???i kno dat he is runnin a stock auto p06 ecu..
Old Jun 7, 2009 | 02:30 PM
jdmdikk's Avatar
i think that i need a tcm,where is it located on a integra and can i use a tcm from another car as long as its obd1 and how do i wire it up step by step,,
Old Jun 7, 2009 | 02:39 PM
RyanA's Avatar
If you have to ask where the TCM is in an Integra, you probably don't want to attempt to do this yourself; it's fairly complex. Go to boomslang.com and they can fix you up with a plug and play harness that uses the Teg TCM to run the trans.
98civdx's Avatar
Master Detailer
^^ took the words out of my mouth....
Old Jun 7, 2009 | 02:42 PM
jdmdikk's Avatar
were is it located,i still want to kno,,is it by the ecu or on the drivers side??and can i still wire it in???
Old Jun 7, 2009 | 02:45 PM
98civdx's Avatar
Master Detailer
http://www.boomslang.us/auto.htm
Old Jun 7, 2009 | 02:48 PM
jdmdikk's Avatar
his car is not obd2..his car is obd1 so that wont plug in..so i can basically get a tcm and plug and wire it into the ecu harness..what wire goes to what??thats all i want to kno
Old Jun 7, 2009 | 02:51 PM
98civdx's Avatar
Master Detailer
for the tcm check behind the drivers kick pannle on the teg.
Old Jun 7, 2009 | 03:00 PM
jdmdikk's Avatar
GOOD LOOK..HOW DO I WIRE IT UP???
Old Jun 8, 2009 | 05:20 AM
jdmdikk's Avatar
WIRERING DIAGRAM FOR THE TCM??????
Old Jun 8, 2009 | 05:41 PM
jdmdikk's Avatar
ttt..how do i wire it up??a diagram will help guys
Old Jun 8, 2009 | 06:13 PM
94EG8's Avatar
Seagull Management
Theres somewhere in the neighborhood of around 40 wires to run for a teg automatic TCM, some of them run to the ECU, some to the transmission and some to other places. Its a lot easier to just swap to a 5 speed if you can't get a premade harness. If you do want to wire it up yourself pick up an Integra factory service manual and start checking out wiring diagrams.
Old Jun 8, 2009 | 07:14 PM
98civdx's Avatar
Master Detailer
^^ that to. or just call boomslang and see if they can make you a custom one.
Old Jun 9, 2009 | 04:50 AM
jdmdikk's Avatar
o iight..ill just pick up a factory helms manual.
Old Sep 28, 2009 | 11:28 PM
drone56's Avatar
New User
hey, did you ever figure that diagram out? interested cause i need the same info...
enzoferrari
May 25, 2016 05:52 PM
D3U1LT
12
Nov 25, 2006 03:49 PM
midenginecivic
Mar 10, 2005 07:25 AM
KiNG $h!t
Aug 28, 2003 09:29 PM
