Adding oil press gauge to Oil sand adapter help
Old Jun 6, 2009 | 08:12 PM
Maple50175's Avatar
Default Adding oil press gauge to Oil sand adapter help
So yeah I'm boosted. I have one of those oil sandwich adapter things. anyways I want to use my oil press gauge BUT it doesnt fit on this thing because it like hits the block since it's so close.
How could I use it? I mean would a 45 degree angle thing work? what size would I get I'm super confused becuase you can't do 90degress or it will hit the oil filter....
let me know
Old Jun 6, 2009 | 10:38 PM
rmcdaniels's Avatar
Default Re: Adding oil press gauge to Oil sand adapter help
I used a 1/8" NPT hose barb on the plate and the sensor, then connected them with some high pressure fuel line and mounted the sensor on the firewall.
Old Jun 7, 2009 | 05:06 AM
Antilag's Avatar
Mount the sending unit to the fire wall, get a 1/8npt by -3 fitting. mount the 1/8 to your sandwich adapter, get poss 1.5-2ft stailess line of -3 with -3 fittings on. run that from your adapter to the sending unit.
Old Jun 7, 2009 | 06:08 AM
MadVTI's Avatar
I got a braided steel adapter hose made up and mounted sensor on firewall a others have said. Cheap and effective!
totsie7944
Mar 26, 2008 04:26 PM
sasinorm01
May 9, 2006 06:42 PM
88crxhfb16
Jul 23, 2005 11:02 AM
vr6chris
Jun 8, 2004 04:59 PM
turbotime
Nov 29, 2003 04:58 PM
