99 civic si automatic
Old Jun 6, 2009 | 12:25 PM
edbtz's Avatar
New User
Icon6 99 civic si automatic
hi, im new th this site.
but i ahve a problem, my right rear outside brake light isnt working, i replaced with new bulb and still didnt work
what should i do next?
A answer would be appreciated
Old Jun 6, 2009 | 12:37 PM
civic_driver's Avatar
Default Re: 99 civic si automatic
Check the brake fuse (not sure which one it is off hand) and the wiring for shorts.
Old Jun 6, 2009 | 12:43 PM
edbtz's Avatar
New User
thanks for the reply. i checked the fuse for brake lights it was fine.
for the wiring do i need a test lamp? and were do i start at the wiring?
Old Jun 6, 2009 | 12:47 PM
tweek_boii's Avatar
If its only one side which does not light up any more, problem might be the wiring.
Use the test lamp where the socket is at and if it does not light up , you mights have to go deeper to fin were the wire is harmed..
Old Jun 6, 2009 | 12:50 PM
edbtz's Avatar
New User
yeah its only the one side.
thanks alot i will try that.
Old Jun 6, 2009 | 01:17 PM
tweek_boii's Avatar
no problem.
Old Jun 11, 2009 | 08:53 PM
edbtz's Avatar
New User
i put a test lamp to the socket and it didnt light up, so i got a wiring problem
where do i go next to frind the problem?
Old Jun 11, 2009 | 09:17 PM
Former User's Avatar
The brake lights get power through the Grn/Wht wire and are grounded through the Blk wire. The taillights ground through the same Blk wire, so if it was bad, then the right taillight would also not work. Therefore, test for battery voltage to body ground on the Grn/Wht wire at the rear of the bulb socket while a friend is pushing down on the brake pedal. If battery voltage is detected, inspect the bulb socket for damage. If not, trace the Grn/Wht wire back looking for a break.
Old Jun 12, 2009 | 10:49 PM
edbtz's Avatar
New User
okayy thanks alott man
appreciate it
Old Jun 13, 2009 | 06:30 AM
Choy's Avatar
uh i dont think 99-00 si's come auto
Old Jun 13, 2009 | 09:26 AM
edbtz's Avatar
New User
yeah they do in canada - there like ex model but in canada you get the si
Old Jun 13, 2009 | 10:44 AM
CivicSD's Avatar
my thoughts exactly, i forgot about the Canada thing!
Try another bulb.
Old Jun 13, 2009 | 03:13 PM
edbtz's Avatar
New User
loll yeah man
i fixed the problem there was a broken wire
boush95ls
Apr 30, 2009 01:42 PM
la bliintsz
Nov 12, 2008 11:21 PM
96teggynonVtec
Sep 2, 2008 09:35 PM
toEknEEg
Oct 6, 2003 04:04 PM
