Little problem...
I have a 99 Honda Civic EX. I replaced the Compressor and condenser fan and have recharged the system. The A/C blows pretty cool air on the highway when it's not too hot outside, but in the heat...it seems to be noticeably cool... but definitely not cold. Any suggestions? The compressor is functioning and the fan comes on.
Also, how hard would it be to install a distributor for this car? Is it as simple as 3 bolts and an O-ring? Do I need any special tools? Will the car automatically adjust the timing? Thanks!
cant help with your a/c but yeah 3 bolts and an o ring, timing wont adjust its self but if you install the new distributor in the exact same position as the old 1 you should be okay, use little marks 2 help you out installing it
phelpsj2
Aug 20, 2009 08:08 PM
christian7750
May 7, 2007 11:29 AM
