Need help with 97 GSR in 00 EK
im plaing on puttin in a 97 gsr in my 00 ek and basically what needs to be done besides getting si harness, si rear t bracket and post mount n mount. what els do i need to do to make it work?? i hear something about the secondary to the butterfly or something? im not so sure all your inputs will help thanks!
depends on what ecu you're gunna use. if you're gunna use a p72 then ya, you need to hook up the IAB (intake air bypass) on the GSR intake manifold. just replace the manifold with a skunk2 manifold and use a p2t (99-00 si) or p73 and you wont have to worry about it
DeucesWild
Apr 2, 2008 12:01 PM
