98 b18b1 into 97 ek ferio
I was wondering if anybody had any insight about the b18b1 being dropped into an ek. Is it a direct drop in? And do I have to use the engine harness from the integra or jus use the ek harness? Will the motor mounts line up the same or do they have to be change? Im currently trying to get the car bar'd with a b18b1 so any info would be greatly appreciated. Thanks!
Re: 98 b18b1 into 97 ek ferio
ok so you will use your existing wireharness off your ek. You will need a 99/00 si rear "T" bracket and driver side si block mount. The top tranny mount will be off your stock motor. Axles and shift linkage from 99-00 si also or 94-01 integra.
Pretty much direct drop in since you wont be doing any wiring or anything of that nature. hope that helps
dthug
10-24-2010 05:57 PM
bakomack
07-29-2009 02:15 PM
LilKrnThugBoi253
02-28-2007 10:56 AM
