ARE DEL SDL STRUTS THE SAME AS CIVIC
looking for a set of coilovers for my 93 del sol , and two websites state 92 to 95 civic ( except del sol) is there any diffrence between civic and del sol?
The only difference between 92-95 Civic, 94-01 Integra (excl. Type R), and Del Sol coilovers are the spring rates. Most of the other suspension components are compatible too so long as you put some thought into it - ABS parts for ABS cars, rear disc parts for rear disc cars, etc. 96-00 Civic coilovers can be used but the rear LCA uses a smaller bushing so you should avoid them if possible (and don't swap in a 96-00 rear LCA because they're longer).
There is a FAQ on part compatibility, linked from Syndacate's "NEW FAQ'S INDEX - '92-'00 CIVIC / DEL SOL" sticky at the top of the forum.
The only difference between 92-95 Civic, 94-01 Integra (excl. Type R), and Del Sol coilovers are the spring rates. 96-00 Civic coilovers can be used too but the rear LCA uses a smaller bushing so you should avoid them if possible. Most of the other suspension components are compatible too so long as you put some thought into it - ABS parts for ABS cars, rear disc parts for rear disc cars, etc.
i had eg coilovers in my delsol without any problems!!
fryman
Mar 1, 2009 06:22 AM
speedbreed
24
May 2, 2004 07:22 PM
bubbajim
29
May 12, 2003 04:47 AM
1996, 2001, 9200, civic, compatibility, compatible, del, delsol, differance, difference, google, same, sol, struts, sturts
