Bleeding the cooling system
Old Jun 5, 2009 | 11:19 AM
Paulie10's Avatar
New User
Default Bleeding the cooling system
When I bleed the cooling system on my 93 accord are these the steps I should follow.
1. fill radiator to top with fluid
2. replace rad cap and start engine
3. open (or totally take out not sure which) bleed screw
4. wait until a steady stream of coolant seeps out of bleed opening
5. tighten screw and fill radiator when cool
Old Jun 5, 2009 | 04:13 PM
92civlude's Avatar
Default Re: Bleeding the cooling system
Dont have the car running with the bleeder loose. If the thermostat is closed and the car is cold, air will get sucked in at the bleeder.
Old Jun 5, 2009 | 04:41 PM
nysdriver's Avatar
You are also supposed to run the engine with the radiator cap off until the cooling fan comes on at least twice. Makes a lot of mess, but you will see tons of air coming out.
Don't forget to set the heater temp dial to max before you start, too.
Old Jun 5, 2009 | 09:37 PM
jonesdesign's Avatar
anyone know if this applies to all 90-93 accord models?
Old Nov 8, 2009 | 04:34 AM
madracer's Avatar
Where is the bleed screw????
Old Nov 8, 2009 | 07:19 AM
redbull-1's Avatar
It is usually shown in your owner's manual. But if you don't have it, post the year of the car and model (e.g. 19XX Accord, Civic) or google.
Old Aug 11, 2010 | 09:22 PM
Bad_dude's Avatar
Icon2 Re: Bleeding the cooling system
What is the torque spec for the bleeder screw?
Thanks.
Old Aug 11, 2010 | 09:25 PM
holmesnmanny's Avatar
Doesn't need to be tight, you'll know when it's tight enough 'cause it'll stop spewing coolant. When you do bleed, make sure you to turn your heater blower on full blast.
I'm gonna find my service manual and get the right specs.
Old Aug 11, 2010 | 09:27 PM
7lb-ft dude
Old Aug 11, 2010 | 09:29 PM
I just found the drain bolt for draining the block it's just to the left of the oil filter, 36lb-ft
Old Aug 11, 2010 | 10:03 PM
Bad_dude's Avatar
Is it under with the oil filter or on top in the engine bay? And when do you need to drain the block?
Thanks.
Old Aug 11, 2010 | 11:37 PM
Thanks.
to the left of it, you would need to if you remove the thermostat housing when doing the intake manifold as we're talking about in that other thread and when taking out the water pump, head off, stuff like that.
Sean McClain
Jul 3, 2017 08:31 AM
civicboisi
Feb 22, 2007 05:38 PM
istabrak
May 4, 2006 11:51 AM
briq4
Mar 4, 2006 02:10 PM
DFW
Jan 29, 2005 07:57 AM
