89 CRX W/ B16a swap squeal on acceleration.
Old Jun 5, 2009 | 10:15 AM
camp_kill_yourself's Avatar
Default 89 CRX W/ B16a swap squeal on acceleration.
It’s strange it will squeal any time I’m starting from a dead stop all the way trough 3rd gear, I was told it was an axel but I also heard it was a “trough out bearing” I’ve never heard of that bearing so I don’t know what I’m looking for, I was told it was around the tranny. As for the axel part it does not clunk when turning or make any other noises; I’ve dropped the clutch hard a few times and nothing out of the ordinary occurred. I’m at a loss I don’t want to trough money at a problem I can’t pin point. Any ideas?
Old Jun 7, 2009 | 09:21 AM
Default Re: 89 CRX W/ B16a swap squeal on acceleration.
Bump!
Old Jun 7, 2009 | 11:10 AM
alex_b's Avatar
the throw out bearing is in the clutch/flywheel area. might want to check out the pilot bearing too.
Old Jun 7, 2009 | 11:47 AM
crx_si-r's Avatar
my LSV does the same thing every now and then but it sounds more like if i was peeling out.
Old Jun 10, 2009 | 08:03 AM
Yeah thats what i thought it was at first! is the bearing hard to replace/repair?
Old Jun 10, 2009 | 08:16 AM
redflaredcrx90's Avatar
check you alt belt make sure it not cracked
Old Jun 10, 2009 | 08:20 AM
crx_si-r's Avatar
Everything on my car was new, I just learned to deal with it. The lsv is only temp for me till my itr is built. This way the rex will be all set.
Old Jun 10, 2009 | 08:36 AM
sde780's Avatar
Check your belts
Old Jun 10, 2009 | 10:03 AM
EL Vap133's Avatar
I would check it also, sometimes it might be too tight as well.
Old Jun 10, 2009 | 10:17 AM
The alt belt looked good the other day when i checked it but i will look again just to be sure...
Old Jun 10, 2009 | 10:20 AM
how tight should the belt sit? any way to tell by hand?
Old Jun 10, 2009 | 10:25 AM
Cole89ef's Avatar
You should be able to grab the belt and turn in 1/4 to 1/2 way. If you can't turn at all its to tight, if you can turn more it is to loose.
Old Jun 10, 2009 | 10:26 AM
Nice thatnks ill check that right now!!
Old Jun 10, 2009 | 10:29 AM
that thing doesnt turn at all! i tryed bolth ways and not an inch...justto make sure i did it right i was supposed to pull the belt like it was normaly running in the car right?
Old Jun 10, 2009 | 10:33 AM
hondafleet82's Avatar
Def your acc belt or alternator belt if you cant turn it. you should be able to loosen the tensioner and fix the issue. just make sure you dont in turn loosen it too much.
Old Jun 10, 2009 | 10:51 AM
All i need to do is loosen the bolts holding the alt to the car and rotate it ? kind of like a distributer.
Old Jun 10, 2009 | 11:10 AM
sde780's Avatar
Yea the alternator pulls towards you if you loosen the bolt
Old Jun 10, 2009 | 01:24 PM
I'll adjust the alt when im off work at 400 but if its what i think it is (axles) the what axels should i get the axels for a crx or for a b16A?
Old Jun 10, 2009 | 08:08 PM
96-01 INTEGRA AXLES
Old Jun 11, 2009 | 09:59 AM
So i checked the alt belt it was infact loose so i tightend it down and still have the problem I have no idea how to check the trough out bearing or the pilot bearing, is that some thing i can do myself?
Old Jun 11, 2009 | 10:39 AM
crx_si-r's Avatar
yes you can do it yourself, but you have to drop the tranny to check em out.
Old Jun 11, 2009 | 11:23 AM
UGH i dont have the know how to complete a task like that
Old Jun 11, 2009 | 11:27 AM
crx_si-r's Avatar
its pretty simple. may take some time, if you need to change your clutch i suggest you do it at that time. i dont mind helping, hit me up looks like your in sac as well.
Old Jun 11, 2009 | 11:47 AM
Yeah for sure. Thanks Bro!
Old Jun 11, 2009 | 11:56 AM
91whiteREX's Avatar
What tranny do you have? I have a y1 lsd tranny, when i bought new axles i bought raxle ones for the y1 tranny. The axles depends on what intermediate shaft you have.
