Okay so I cleaned my IACV
Old Jun 5, 2009 | 08:09 AM
xtopherx's Avatar
Default Okay so I cleaned my IACV
And it's still fluctuating in idle after warming up. It doesn't do it when it first starts, only after it's been running a bit. I took off the idle air control value last night and used almost a whole can of brake cleaner. Still fluctuating from 1000 to 1500 fairly rapidly.
Crap.
Old Jun 5, 2009 | 08:12 AM
JAYB90's Avatar
Default Re: Okay so I cleaned my IACV
same problem i have, i heard cleaning usually dosent do the trick. replacing it with a good one should do it. Or mabey cleaning your FITV/ check for a coolent leak and check spark plugsss
Old Jun 5, 2009 | 08:31 AM
xtopherx's Avatar
Just replaced my plugs. Gonna clean my FITV tonight I guess.
Old Jun 5, 2009 | 08:33 AM
dephtone's Avatar
Did you refill and bleed the coolant system? Might have air bubbles in the system still. I'v heard to also when the car is up to op temp to turn the heat on (if you have it) to ensure that you have all the air out of the heater core also.
Old Jun 5, 2009 | 08:35 AM
JAYB90's Avatar
is it a dual or multipoint?
Old Jun 5, 2009 | 08:38 AM
xtopherx's Avatar
You know, i didn't do that. But now that I think of that, it makes tons of sense. I'll do that, most def.
Old Jun 5, 2009 | 03:07 PM
kg_civic's Avatar
New User
Try resetting your ECU by disconnecting the battery for a few minutes.
Old Jun 5, 2009 | 03:37 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Or just pull the hazard fuse for 15 seconds and keep your radio settings...
1fastvtec
Jan 26, 2015 05:12 PM
Da_1991
Apr 8, 2014 09:01 PM
torinharrington
Jun 14, 2013 07:29 PM
E-spec Tuner
May 29, 2004 10:30 AM
Liquidgsr
Apr 2, 2004 06:19 PM
