ls vtec + s300 = no vtec
Old Jun 4, 2009 | 08:55 PM
1sikhatch's Avatar
Default ls vtec + s300 = no vtec
i have a built ls/v swap tuned on hondata s300, my vtec wont pop for ****, its in a 96 ex, i swapped out the vtec solenoid and it worked once, no cel all sensors and wiring are good, great oil pressure, can someone help me out
Old Jun 4, 2009 | 10:56 PM
MONSTERek4's Avatar
Default Re: ls vtec + s300 = no vtec
make sure ur oil pan aint smashed from the bottom
Old Jun 5, 2009 | 04:41 AM
1sikhatch's Avatar
nah oil pan is new, moroso 5 qt
Old Jun 5, 2009 | 05:13 AM
93turbo16's Avatar
What base ecu are you using?
New oil pump?
Have all the o-rings in the head and in the block?
Have all the pins in the rockers?
Old Jun 6, 2009 | 05:58 PM
h46it's Avatar
Did you check in the "VTEC" in the parameter section that the rpm's are the not the same for lower and upper boundary? If they are the same you must change one to a different value to have VTEC to work.
Mopedstud
Aug 2, 2010 10:18 PM
EJ8chu
May 26, 2008 12:53 PM
civic_jdm16
Apr 26, 2007 10:21 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
clos0821
13
Sep 8, 2004 11:01 AM
