issue bleeding brakes searched
sorry im sure this is the wrong forum for this but im looking for info from the suspension guys more then speculation in the other forums... heres the deal. 96 gsr, removed the abs system and did the rs brake conversion since i got this car while it was in pieces... everything is tite and looks to be assembled right. i go to pump fluid through the lines to the calipers and fluid is only reaching the drivers front and the passengers rear... the other two are getting no fluid or air coming through the bleeders. i understand the brake systems are designed in a 2 step incase a brake line fails so you can still drive with cross corners working, which seems to be whats going on. so i plugs the drivers front and pass rear (the two corners that are bleeding properly) and tried to pump the brake system with only the other 2 corners open, hoping the fluid or air would find its way out through those corners... fluid in the resivoir does not go down, nor does any air or fluid come from those bleeders. i have checked the lines for breaks or leaks and there are none... anyone have any clue whats going on??
from my understanding you kept 1 or 2 bleeder screws open while u pumped the brake?
what you need to do is close off all the bleeder screws, pump the brake while you refill your master cylinder (MC) and wait to build pressure in the pedal, once that's done start from (in order) RR,LF,LR,RF and bleed it until no more air bubbles seep through..
the way to bleed is pump 3 times nice and slow, on the 3rd pump hold it while someone opens the bleeder screw and your pedal sinks to the floor board. Then you close off the screw and redo the process until all the air is out of the system
what he said or what i do at times when i have no help is get a soda bottle a vacum line long enough to reach the bleeder screw. Take the bottle put one end of the vacum line in the bottle till it reaches the bottom,fill the bottle with fresh brake fluid (just enough so that the vacum line end is submerged in the fluid) put the other end to the bleeder screw. Open the screw and pump the brake pedal till no air comes ouy (Make sure the line is still submerged in the brake fluid so it wont pick up air) eventually the bottle will fill up with brake fluid. Just do the same at each caliper empty the bottle when it gets full and make sure the master doesent go dry. Also try not to push the pedal to the floor with to much pressure as that can damage the seal and that at times will not let the system build pressure. That is a home made 1 man brake bleeder.
thanks guys
