Caliper Piston Spinning But Not Compressing
Working on the right rear brakes of a 98 Prelude. The piston is spinning, but isnt compressing. I have the bleeder screw opened and have turned it many times in both directions. Any ideas? Thanks in advance!
Why would you turn the bleeder screw in both directions, lefty loosy righty tighty.
Also gravity bleeding is a last resort in just about all cases. You want to limit the fluid's exposure to air since its hydroscopic, which means it absorbs water. By exposing the fluid to air you run the risk of lowering the fluids boiling point, the water can cause corrosion on the internal of the braking system.
rdssk8rcs1
10
Apr 11, 2008 04:54 PM
_jester_
14
Nov 26, 2003 04:55 AM
