master brake cylinder - upgraded? oem replacement
Old Jun 4, 2009 | 12:22 PM
dailydrivenHONDA's Avatar
Default master brake cylinder - upgraded? oem replacement
ok so i got a 93 ex sedan wit an ls swap. it came with factory 4 wheel disc brake and abs which from what i have come to learn was not a common thing in 93. anywho, i converted to integra disc brakes and years later my master brake cylinder is starting to leak, and was been having slight decrease in pedal feel and stopping power.
question is - is there any factory honda replacement that would work as an upgrade i.e. ctr/itr master brake cylinder or accord? dont know if they would work or if any gains would be had to convert. any help would be great about the topic.
Old Jun 4, 2009 | 12:28 PM
thumper64's Avatar
Default Re: master brake cylinder - upgraded? oem replacement
Isn't the ABS MC 1"? You can't really get bigger than that. If you need a new master cylinder, just look for one off a 1994-00 Integra with ABS, so anything but the RS I think. (The fittings are different)
You could put stainless woven brake lines on, like the Stoptech ones or some others with a coating over the stainless weave. That would improve pedal feel.
Bleed the brakes well. Get some good pads and rotors. Otherwise you can do another brake swap. I'll let you search on that one.
Old Jun 4, 2009 | 01:00 PM
i know of other brake swaps/upgrades but just didnt know how interchangable the mbc is on hondas. il just get a new OEM on or maybe on off a dc2
Old Jun 4, 2009 | 01:19 PM
1992Si's Avatar
Can't you get a reman at the auto parts store?
http://shop.advanceautoparts.com/web...AMS__brakes___
Old Jun 4, 2009 | 02:50 PM
g230sport's Avatar
im having the same problem on my 94 coupe, i know its the mc, its leaking onto the booster...
i know i will def be getting a NEW one, not a rebuilt one... for brakes, i dont think i could trust a reman... im picky though
Old Jun 8, 2009 | 01:16 PM
reman's are garbage.
fongph
Jun 16, 2006 06:05 PM
VTECth1s
Jun 9, 2006 06:21 PM
DRKSol
Sep 14, 2004 09:04 AM
DMF
15
Feb 1, 2003 04:02 PM
