Will GSR Fat Fives work
Looking at getting a set of Fat Fives, from the research I did they should be +38mm offset, my stock fit sport wheels are +55. Just wondering if anyone has any experience with these, and if they will work without spacers?
Where did you get the info that fat fives were +38mm offset? Seems a little low.
But for the most part, I don't see why these wheels would not fit. The only problem I see is the size tire that you put on it (unless you're buying new tires for them, or use the correct size tire for your car).
GSR fat fives offset are +45, but I am not 100% sure. They should/might work on the Fit but you must get them on there first to make sure they do not rub against anything.
Also tires will play a factor if you are lowered, 50 series, 195 or 205, etc..
they do not rub go for it ditch those 55 offset wheels and the 35 offset seems right for the fat fives as my EM LX SE wheels also have a much lower offset. you can run up to a 205/50/15 tires with out spacers.
WHITE DEATH
Dec 30, 2004 02:08 AM
gsr98vtec
Jul 24, 2002 08:28 PM
uncleben
20
Feb 13, 2002 08:02 PM
