windshield wipers won't go down or move
Old Jun 4, 2009 | 06:23 AM
bdmlilburn's Avatar
Default windshield wipers won't go down or move
96 accord ex
my windshield wipers are stuck in the up position trying to turn them on does not make them do anything. however when the car is on they will jerk left to right every so often about an inch or so like they are getting a little jolt of power.
blown fuse maybe? gonna take a look at this later today. gotta get some sleep after a long night of drinkin. where should i start looking to find the problem
Old Jun 4, 2009 | 07:45 AM
coregis's Avatar
Default Re: windshield wipers won't go down or move
The first thing I'd check is that the wiper arms are on good and tight. Where the arm meets the car, there is a little 'nub' that you can tighten with a wrench or maybe even a socket if you want to get fancy. Mine get loose every once in a while, and the wiper then is frozen but it's usually one at a time. If you turn the wipers on, you'll see the little nub moving I think. Either way, can't help to tighten it. Might be something worse though, but that's what I'd do first.
Old Jun 4, 2009 | 10:32 AM
bdmlilburn's Avatar
im sure with my luck its worse. i just removed my abs so had a bunch of **** unplugged. i still gotta go check the fuse and check all the electrical connectors and make sure they are all good. i know i tightened those nubs down. i wish it was gonna be that easy
Old Jun 4, 2009 | 02:34 PM
alkoholikwun's Avatar
there was a thread here a while back around winter, a few people lost movement for the wipers due to snow piling up on it.
https://honda-tech.com/forums/showth...ndshield+wiper
Old Jun 7, 2009 | 06:05 PM
bdmlilburn's Avatar
found out the problem was when i screwed the wiper blade back on i didit whil they were up. loosening the blades some and pushing then down to start up position fixed the problem
leadtrum
25
Oct 30, 2019 08:23 AM
mgold
Mar 29, 2012 07:03 PM
invision
Jan 19, 2008 11:08 AM
GraphiteMW
May 23, 2007 08:56 AM
hamburgler
Sep 16, 2005 03:40 AM
