Help - Shift Linkage Stabilizer Bar
Old Jun 4, 2009 | 03:29 AM
Dchase's Avatar
New User
Default Help - Shift Linkage Stabilizer Bar
I just finished a B18 swap into my 93 hatchback..
When I was tightening in the shifter linkage stabilizer bar, the bolt tourqued off. Whats the best way to fix this?
I thought about using a stripped screw remover, but have never had luck with those. Can I just pull the stud out of the tranny and replace it?
Any help will be appreciated
Old Jun 4, 2009 | 04:52 AM
Zumo's Avatar
Default Re: Help - Shift Linkage Stabilizer Bar
Can you post a pic of what it looks like? The damage?
Old Jun 4, 2009 | 05:09 AM
Dchase's Avatar
New User
Yeah, Im at work right now..
I will get on up after lunch if I can.
Old Jun 4, 2009 | 05:16 AM
weavertime1's Avatar
Do you mean the bolt that goes into the transmission? If so, that depends on how much of the bolt is left. You may be able to get vise grips on it after you remove the bar. Also it depends on if you just overtightened it, or cross threaded it.
Old Jun 4, 2009 | 05:23 AM
1992Si's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Do you mean bolt #30 in the picture.?
Old Jun 4, 2009 | 05:26 AM
Dchase's Avatar
New User
There isn't enough left on the bolt to grab it with vice grips, its pretty much flush with the mount..
The bolt is about half way in, It was going in fine so I'm positive its not cross threaded, got stuck then snapped off.
Old Jun 4, 2009 | 05:31 AM
1992Si's Avatar
Worst case is you drill it out and install a insert.
If you need to drive it, you should be ok. How much HP you making? If stock, I'd say no biggy.
I don't know how it would've got "stuck" but what I would do would be to drill a small hole in the bolt and use an easy out. Other than that, there really isn't any other way if it is broke flush in the transmission. Good luck!
Old Jun 4, 2009 | 05:41 AM
Dchase's Avatar
New User
Yeah thats the one.
Yeah the B18 is stock and will probably stay that way.
I will try drilling into it and using an easy out.
Alexpro
Jun 15, 2015 12:25 AM
95EG2
Feb 28, 2010 03:38 PM
spoonracer84eg
Aug 27, 2006 11:52 AM
StolenTeg
Aug 12, 2006 08:04 PM
allmotorls95
Sep 10, 2002 09:00 AM
