need helping taking ignition off.
i am trying 2 figure out a easy way 2 take off my ignition key.i am changing my steering column nd theres no way i can get a grip off those 2 bolts cause there flat.ne advice would help.
Hmm, I removed mines once awhile back..., what i did was took a flat head screwdriver and a small hammer and nicked the edged of the bolts till it was loose. took me a good 45 mins to an hour to remove it. Becareful about swinging the hammer tho since u hardly have any room, you might accidently hit the front wind shield. Good luck.
From: birthplace of "Battle of the Imports" palmdale, CA
They're supposed to be like that for security reasons.... The way to take them off is to get a drill and a 3/16 drillbit or smaller I don't remember.( which ever fits in the center of the bolt). Then you drill straight into the bolt ( the center is made soft ) and once you get through the soft part the drillbit will catch and unscrew itself... Should only take like two min each bolt (4min)...
UserX826
10
Feb 21, 2009 10:02 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
