Clutch promblem
Hi! I'm changing 3rd clutch disk on my D16Y8, during 4 month
few days ago i putted in new clutch disk and pressure plate, but clutch is slipping and still engages when the pedal is in middle of it's way, and engages strange not quickly as new clutch should do, but slowly during whole pedal release. i changed clutch master cylinder, but it still bad. car takes only 50 km/hr on first gear, while it should take 60
flywheel is good.
what could it be?
flywheel is good. what could it be?
Check the freeplay. The freeplay is the distance between the clutch engagement point and a point further back from the clutch master cylinder piston. There should be some freeplay in the clutch pedal, otherwise the clutch will slip constantly.
i have 1 cantimeter freeplay on the pedal. i did not get new flywheel, just checked mine and it is fine. pressure plate is new and torqued down to spec. could it be bad slave cylinder ot bended release fork?
Smcneal1970
Jun 11, 2018 06:54 AM
