S2000 Steering Wheel in EK
Old Jun 3, 2009 | 12:34 PM
RyosukeFC3s's Avatar
Default S2000 Steering Wheel in EK
So I have installed an s2k steering wheel in my car. However my airbag doesn't seem to work.
Also my horn would remain on (without pressing it) if I plug it in.
Does anyone have any experience with an S2k wheel in their car and have some advice to give me?
Thanks,
Dan
Old Jun 3, 2009 | 01:17 PM
Dac's Avatar
Dac
Default Re: S2000 Steering Wheel in EK
My roommate had an s2k wheel in his 2000 si. Everything works right on his (horn, air bag, & cruse control). He's a tech at honda and had to splice wires into the clock spring to get it to work correctly. What year of steering wheel are you trying to use? He said something about only being able to use a couple of years of s2k wheels on ek's...
Old Jun 3, 2009 | 01:57 PM
eskimo10's Avatar
I just recently put an S2000 wheel into my EJ8. In my experience it was completely plug and play with the exception of the cruise control. I had to re-pin the plug from the car side to make it work with the S2000 cruise. PM me and I can walk you through what I did.
Old Jun 3, 2009 | 02:09 PM
I thought it was supposed to be plug and play. I don't have cruise control on my car so I didn't have to do any wiring.
I'm thinking maybe I messed up my ground wire and that's why the horn isn't working properly. But I still can't figure out the airbag issue. I replaced the clock spring already, thinking it was that. But still the light comes on.
Old Jun 3, 2009 | 02:11 PM
Oh I also wanted to note that my SRS light was on when I had the stock steering wheel as well.
Old Jun 3, 2009 | 02:50 PM
EJ8chu's Avatar
Then reset the SRS system and see where you are at.
Old Jul 14, 2009 | 05:09 PM
civy123's Avatar
Any info on what years work in an ek??? I have a 02' s2000 wheel I am looking to put in my coupe but havent had time to do it yet.... What has to be changed? Modded or repinned
Old Jul 14, 2009 | 05:55 PM
BlueIntegraBoy's Avatar
00-03 wheels (AP1) are plug and play
Hatecity24
Aug 7, 2012 02:59 PM
Jap_Spec_Imports
Aug 11, 2009 06:33 AM
Historyg
17
Nov 22, 2007 11:15 PM
mtny
Jul 27, 2006 05:27 PM
ricky05
Mar 5, 2006 01:22 AM
