Need CV Axle driveshaft **Any difference between ABS vs. Non**
Old Jun 3, 2009 | 08:30 AM
kroze's Avatar
Default Need CV Axle driveshaft **Any difference between ABS vs. Non**
I need to replace my CV Axle driveshaft but just wondering are there any difference between buying one with or without ABS?
I saw a bunch of them on ebay and they all listed that it will work with or without ABS car.
Old Jun 3, 2009 | 09:22 AM
1200 Hobos's Avatar
Default Re: Need CV Axle driveshaft **Any difference between ABS vs. Non**
If you have an ABS axle it will work wether or not you car has ABS.
If you want to retain your ABS, a non-ABS axle won't work.
Old Jun 3, 2009 | 01:39 PM
sportsman1539's Avatar
actually there is a difference. the splines on the end of the shaft on the half shaft end on the abs shaft go only half way down the shaft. The non abs go all the way down. Kinda hard to explain but I had one boxed wrong one time and got the abs and it wouldnt work.
EG civic
Nov 11, 2020 11:44 PM
rhdins
Sep 19, 2009 08:17 AM
94_teggy_rs
Jan 28, 2008 08:36 PM
GraphiteMW
Mar 5, 2007 05:04 PM
fakemike
13
Feb 20, 2005 04:16 PM
