Leaky exhaust valve 94 civic dx minie me swap
like the title says,
i dont know what to do, either adjust the valves or something,
i have searched and nothing. just need to know what to do asap, i need the car by 10:30 am.
its leaking on the first cylinder closet to the driver side
If the valve is bent you will need to replace it. Otherwise you can adjust the valves and it should be good to go unless the valve and other parts are worn out.
It seems more likely that the valve stem seal is bad. If the valve is bent, then you would have low cylinder compression. Have you compression tested the cylinders?
