Suspension & Brakes Theory, alignment, spring rates....
Booster problem?
Old Jun 2, 2009 | 07:01 PM
lsnidex's Avatar
Default Booster problem?
I've been noticing lately that when I hit the brake lightly, I can feel it losing pressure very slowly, and if I sit there and push slowly down on it when I'm stopped, it will eventually go down to the floor.
No leaks in the lines, and I've bled them already. When I'm idling, if I push the brake pedal down and let up, it will go from idle up to about 1300rpm, then fall back; which leads me to believe the booster is going bad.
Help is appreciated...
Old Jun 2, 2009 | 07:04 PM
92CivicB16's Avatar
Default Re: Booster problem?
thats what it sounds like. There is also a rubber gasket that goes in between the master cylinder and the booster. i would check that also before buying a whole new booster. also check all the vacuum lines
Old Jun 3, 2009 | 08:27 PM
drift2004's Avatar
do u have the check valve on the brake hose from the marter cylinder and the intake manifold
mikej94civex
May 11, 2010 08:39 PM
ZippyZivic
Mar 24, 2009 07:58 PM
CRITTERMATT
Dec 4, 2007 09:37 AM
dxhatch92
Jan 16, 2007 08:13 PM
snoop_bealybob
Oct 18, 2002 04:49 AM
