tuned numbers still low
well i got tuned a few weeks ago. i am just wondering y i am down on power and trying to get a few ideas on how to make it more efficient id like to be able to make alittle more.
it was hot the day i got tuned and my car was getting high iat and blew every vac source i had on it off but after i fixed that things went smooth. the turbo was pulling hot air from the fan but i expected more from 18-22 psi the car did trap 117 tho. so i guess my options are to try to add a pipe and filter to the turbo even tho i dont have much room or clock the turbo i was trying to stay away from this cause i would need a new downpipe but if its gotta be done ill do it. just looking for ideas and suggestions.
set up
81.5 mm ls block and crank
cp pistons 9.7.1
eagle rods
head
omni valve springs and retainers
gsr cams
stock intake manifold (victor x will be next )
peakboost ftw ac kit
57 trim 82a/r
s300 with pwm boost control.
set up
cp pistons 9.7.1
eagle rods
head
gsr cams
57 trim 82a/r
lol, i am running the peakboost ftw ac kit with a 57 trim 62 ar and i made only 260 on 16 psi on 93 octane. this was a few months ago and i came to the conclusion it was a mixture of a couple things
1)the wastegate in the kit dumps right under the intake of the turbo
2)the intake is also pointed right in front of the radiator
3)in my case i was running a mishimoto aka JUNK intercooler
for me....i think it was the combination of sucking in hot air combined with the inefficiency of the intercooler causing such low number.
im about to go back to the dyno in a couple weeks. i am now running a bigger turbo, precision intercooler along with an actual intake routed away from my radiator and dumptube.
if the numbers dont significanly improve my civic will be parted out, haha
ive did a compression test everything was great its a fresh motor also less then 2k on it
but i guess i should go out and buy the tools to do leakdown anyway i will try this and report back and timing is great been checked 3 times so far and s300 shows it being fine.
did you do the timing sync??? ive seen this hold a car back big time. Just sync'd the timing and gained 50+hp.
by syncing it i mean, in the top tabs there is a timing sync line, click it, and it disables the hondata timing adjustments, you set the distributor to the timing number given in the window on hondata, then click ok. hope this helps
the above timing sync is f-ing me too. my s200 doesnt have that option, and my timing @ the crank is like 12, while my hondata thinks it's 18. made only 254 @ 8lbs.
well i am happy its trapping that fast but i expected more i could have made 300whp on the stock block.my cars weight is 2640 its got no ac or ps and rear seats but still a full size spare and stuff when i got it weigh. i will get around to checking the timing and doing a leak down test this week i will keep you guys posted.
boosted91crx
Nov 21, 2011 08:24 AM
Powelly
Jan 19, 2009 05:32 PM
gsp ej1-em1
Nov 15, 2006 10:58 PM
