just got dyno got a question???
Old Oct 15, 2007 | 02:52 PM
high_octane's Avatar
Default just got dyno got a question???
OK i just dyno my car and was wondering if i am making the right power. My set up is a 83mm benson sleeve b18c1, 9;1 cp piston, pauter rods, stage 4 head with stock gsr cams. Running a full race turbo kit with a t4/t67 turbo on 1000cc injectors with hondata s300 with boost by gear.
Got my car tune and made 540hp on 28 psi should i be making more horsepower??
Old Oct 15, 2007 | 03:44 PM
bump
Old Oct 15, 2007 | 06:30 PM
blackeg's Avatar
Default Re: (high_octane)
what gas and what intake manifold, exhaust...
it might be a little low, but depending on other variable could be within accepted range?
also, whats your afr and timing look like???....
Old Oct 15, 2007 | 06:55 PM
civicjdmb16a's Avatar
Default Re: (blackeg)
what kind of dyno....? that could make a world of difference
Old Oct 15, 2007 | 07:23 PM
DaveF's Avatar
Default Re: (civicjdmb16a)
you should be able to make a good bit more power at lower boost levels with some differant cams. the new cams will also give a much larger power "band"
Old Oct 15, 2007 | 07:27 PM
it was on a mustang dyno runing 110 octane. Runing a skunk 2 intake manifold. A/F was at 11 to 12s
Old Oct 15, 2007 | 08:04 PM
markaria's Avatar
just to give you a quick comparison... ironically I have a 83mm benson sleeved itr block with 9:1 cp's/pauters and a stock itr head with a sc6152e... on pump gas it made 387 whp/270ft/lbs on a mustang dyno and on a dynopack it made 442whp/316ft/lbs on 2 LESS psi!
I would have to say you would most likely have made a good bit "more" power on another type of dyno. Most likely in the neighborhood of 600whp.
imho nice #'s!
Old Oct 16, 2007 | 06:40 AM
Default Re: (markaria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria &raquo;</TD></TR><TR><TD CLASS="quote">just to give you a quick comparison... ironically I have a 83mm benson sleeved itr block with 9:1 cp's/pauters and a stock itr head with a sc6152e... on pump gas it made 387 whp/270ft/lbs on a mustang dyno and on a dynopack it made 442whp/316ft/lbs on 2 LESS psi!
imho nice #'s!</TD></TR></TABLE>
i had almost the same numbers with my 85mm b16 w/sc61
Old Oct 16, 2007 | 06:51 AM
morgan@synapse motorsport's Avatar
Default Re: just got dyno got a question??? (high_octane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high_octane &raquo;</TD></TR><TR><TD CLASS="quote">OK i just dyno my car and was wondering if i am making the right power. My set up is a 83mm benson sleeve b18c1, 9;1 cp piston, pauter rods, stage 4 head with stock gsr cams. Running a full race turbo kit with a t4/t67 turbo on 1000cc injectors with hondata s300 with boost by gear.
Got my car tune and made 540hp on 28 psi should i be making more horsepower?? </TD></TR></TABLE>
like everyone here has said every dyno reads differently, the track never lies though. can you post a picture of the dyno graph. that skunk2 manifold is likely a big restriction in the upper rpms where a turbo that big will make the most power.
Old Oct 16, 2007 | 07:09 AM
Topdawgg's Avatar
mustang dyno is the reason.... 28psi with that setup should be around 600+whp IMO
Old Oct 16, 2007 | 05:47 PM
thats what i was going for 600 plus hp but still stump on why i only made 540 hp...also had a buddy check my vavle ajustment and he said that they were not adjusted right, could that be the reason why i didnt make the hp i should?
Old Oct 16, 2007 | 05:54 PM
A.E Motoring's Avatar
go dyno on a dyno jet then come back to us and tell us what u made , a better intake manifold will help you
Old Oct 18, 2007 | 04:11 PM
ok just got retune an i made 565 hp on the same dyno, i did a vavle adjustment and my timing on my dissy was off, i guess on a dyno jet i made 606hp, they had a comparson between mustang an dyno jet on there dyno..
ricetastic
Nov 24, 2013 10:19 PM
hasty91ef
Aug 17, 2012 07:39 AM
type_r_teggy
K Series
11
Feb 26, 2012 04:42 AM
wildoutwhitegsr
21
Nov 19, 2006 10:24 PM
allanonjj
Jun 7, 2005 05:11 PM
