compression
Old Jun 2, 2009 | 03:48 PM
typer161's Avatar
New User
Default compression
whats the highest compression i can run all motor on pump gas
Old Jun 2, 2009 | 04:57 PM
Scott_Tucker's Avatar
Default Re: compression
16:1
Old Jun 2, 2009 | 05:06 PM
riceburner700's Avatar
depends on combustion chamber/head design and define pump gas. e85 is considered pump gas as well
Old Jun 2, 2009 | 05:10 PM
typer161's Avatar
New User
going for a ls/vtec with a b16 head
Old Jun 2, 2009 | 05:34 PM
The truth of the matter is that static compression ratio alone never determines whether you can run pump gas. It's static compression ratio together with intake valve closing point that determines the effective compression ratio. The effective ratio is far more important that the static ratio and on an aluminum head/iron block engine is usually about 8.5:1. You can have an engine with a 16:1 static compression ratio and still have an 8.5:1 effective compression ratio but the intake valves would have to close so late that a large portion of the air/fuel charge would be forced back out the intake at low rpm.
tomu06
Mar 30, 2006 03:07 PM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
flip1199
Aug 11, 2004 08:10 PM
90da4dr
Mar 9, 2003 05:18 AM
wickedEFguy
Feb 3, 2003 11:14 PM
