Wiring up horn? No srs harness.
Old Jun 1, 2009 | 10:11 PM
Hanmin's Avatar
Default Wiring up horn? No srs harness.
Alright, no srs harness on my car, and I don't want to buy one.
Which wire do I take from the steering wheel harness? and where does that wire go to?
I'm talking about the yellow steering wheel plug, I think there is three pins in a long connecter. I think one is cruise, one is horn, and the last one is srs.
Old Jun 1, 2009 | 10:15 PM
dyprokski's Avatar
New User
Default Re: Wiring up horn? No srs harness.
yo i think its the blue color, i needs to ground i can help if you want... gary (714) 499-4571 but i have ????`s first
Old Jun 1, 2009 | 10:23 PM
Deetz's Avatar
Crazy Honda Guy
why didn't you just search....it's right in the FAQ section in this forum?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-wire-up-your-horn-aftermarket-wheel-eg-1485735/
Old Jun 2, 2009 | 05:55 AM
Hanmin's Avatar
Thanks, I didn't look in the faqs. I was only able to find the other eg steering wheel onto eg's.
Old Jun 3, 2009 | 08:07 PM
Hanmin's Avatar
Okay, searched plenty of times. This is what I have and I don't want to run wires through the srs.
I have the stock steering wheel connected to the oem steering reel, so I don't want to do the clip trick.
I have the horn wire under my steering column ready to be hooked up somewhere. When I put the horn wire to a hot wire, it works.
I now need to know where to put the hot wire into the long yellow plug on the reel, and where I need to put the horn wire to complete the circuit when the horn button is pressed.
Old Jun 4, 2009 | 08:04 AM
Hanmin's Avatar
I want to run the horn through the relay. Using the stock horn buttons.
On my cable reel there are 4 pins, I used a volt meter to find out which wires go to what, I couldn't find anything. I put a hot wire to each of the pins, and used a light to try and source it, but couldn't find it.
Old Jun 4, 2009 | 09:48 PM
Hanmin's Avatar
Okay, my cable reel, aka clock spring. Whatever you want to call it....
My cable reel was broken, it was attached on upside down. I'm going to buy a new one and make a diy on how to hook up the alarm without the srs harness while continuing to use the stock steering wheel with the horn relay and cable reel.
BolivianFuego
17
Jul 18, 2013 01:27 PM
nojoke
29
Jul 14, 2005 05:07 AM
714eg
Jul 20, 2003 08:36 PM
GReddyB18C
Aug 17, 2002 01:06 PM
forksports
Jan 4, 2002 12:09 AM
