Grinding Wheel for tungsten???
Old Jun 1, 2009 | 06:57 PM
cvcrtonv's Avatar
Default Grinding Wheel for tungsten???
Just wondering what u guys out there are using for grinding your tungsten?Any specialty wheels/grinding stone?I know the wheel should be dedicated to only grinding tungsten and nothing else. Any feedback is appreciated. Thanks
Old Jun 1, 2009 | 07:10 PM
Linh.'s Avatar
Default Re: Grinding Wheel for tungsten???
We grind tungsten with a diamond wheel at the shop I work at.
Old Jun 1, 2009 | 07:22 PM
k24em2's Avatar
You can get diamond wheels on ebay for relatively inexpensive
Old Jun 1, 2009 | 08:16 PM
cvcrtonv's Avatar
Thanks for the feedback. Anyone else?
Old Jun 2, 2009 | 03:30 AM
Adriano's Avatar
I use my belt sander or bench grinder. I have a small bench grinder that I've been meaning to dedicate it just for that.
Adriano
Old Jun 2, 2009 | 04:47 AM
logic-dsm's Avatar
Tungsten grinders. My wife got me Sharpie DX for Christmas a few years back; I never would have actually gone out and bought it myself, but I love that thing.
Old Jun 2, 2009 | 05:12 AM
downest's Avatar
Adriano
Same here, I was taught to use a belt sander and it's just a habit I've kept. Sometimes I use the side of the grinder, but only really if I'm forming a new point from a flat/knocked off tip. For just touching up I use the edge of my sander.
Old Jun 2, 2009 | 06:17 PM
black93octane's Avatar
to answer all your deburring, shaping and sharpening needs: aluminum oxide for high speed tool steels. You need to get a Premium White Aluminum Oxide grinding wheel.. Here is a link to which you can buy one... I work full time in a custom tool shop with mostly all precision grinders... I kno my grinding wheels... If I was grinding a tungsten lathe tool bit I would use a 60J but if you want a polish like finish you could go with a 150 grit or if you just want something between that you could go with a 100j witch is just a 100 grit wheel...
http://www.sharpeningsupplies.com/No...el-P38C20.aspx
If you are going to be grinding carbide you need a diamond wheel which if you click this link you can see a diamond grinding wheel.... http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=64733728
If you are using this info for tig welding.... I would really worry about getting to technical about it.. But if you want maybe you can use this info..
Old Jun 3, 2009 | 04:14 PM
bigtom388's Avatar
I was taught to use a belt sander also works perfect i have tried grinding wheels b4 but i think the belt sander is the best way but thats just opinion.
Old Jun 3, 2009 | 06:24 PM
What kind of tungsten material are you grinding or sanding?
Old Jun 4, 2009 | 05:28 AM
downest's Avatar
I use 2% Thoriated (red I think, R/G colourblind FTL).
Old Jun 4, 2009 | 06:24 AM
shortyz21's Avatar
stone will bring it down quick, then i touch it up on the belt sander or disc sander. also on a side note, breathing tungtsen dust gives u cancer i think...
mind you what doesnt
Old Jun 4, 2009 | 08:05 AM
Fabian's Avatar
as well as smoking...
C_Rock77
Detailing
Jun 12, 2011 07:46 PM
builthatch
Detailing
Dec 18, 2008 05:09 PM
importdude2000
Jan 9, 2007 01:47 PM
stackz
Welding / Fabrication
Feb 9, 2006 03:33 AM
Goullish
23
Mar 27, 2005 10:30 AM
