4 CYL A/C COMPRESSOR PROBLEM
Old Jun 1, 2009 | 06:36 PM
96H4TCH's Avatar
Default 4 CYL A/C COMPRESSOR PROBLEM
Its from a 1995 accord 4 cylinder engine and it starts to leak oil at the bottom?
I was thinking of repairing it but it seems that the body of the compressor is sealed, and looks like theres no way of of opening it except from the front part of it and the leak is coming from the bottom rear...
I was wondering if I can use something to seal the leak up? any brand of sealant that I need to get in order to stop the leaking and is resistant to oil?
Thanks in advance...
Old Jun 1, 2009 | 08:53 PM
pickleboo's Avatar
Default Re: 4 CYL A/C COMPRESSOR PROBLEM
just replace it with another one from the junkyard, why I suggest this well if you going to trouble yourself unbolting it from the frame and trying to take the pulley off it's going to be even more harder then you think I'm saying this its because I tried to take apart a steering pump and it's not fun at all. it also has bolts in the front and the leak was at the front its easier just replace it. at least it will be quick and done with. Otherwise good luck with it taking it apart.
danteisme
Aug 6, 2016 12:06 PM
End3rx
Jun 7, 2012 12:58 PM
curtie94
Jul 24, 2011 01:34 PM
Tip14
Dec 22, 2007 01:17 PM
poly35
Jul 24, 2006 12:03 PM
