CALI BAR QUESTION
Old May 31, 2009 | 09:42 PM
str8drift's Avatar
Default CALI BAR QUESTION
so I have a full 2000 b18b LS swap that was just rebuilt and runs perfect! everything is obd2. SO here's my question. If i put this swap into a obd1 car like a 94-95 teg, or 92-95 hatch ...will i be able to BAR? i will be using a obd1 ecu.
so here's the breakdown... obd2 full swap, into obd1 car with obd1 ECU. will this pass bar? thanks everyone!
Old May 31, 2009 | 10:04 PM
patdow1's Avatar
Default Re: CALI BAR QUESTION
You can put that motor in either of those chasis but the ECU won't pass visual
You will need the ECU for the specific year of your motor.
When I got my B18C1 BAR'd they checked my ECU and even cross referenced it.
Old May 31, 2009 | 10:45 PM
str8drift's Avatar
so i will have to get a 2000 ecu?
Old Jun 1, 2009 | 02:57 AM
Infamax's Avatar
Yes, you need the ecu that corresponds to your engine.
Old Jun 1, 2009 | 06:53 AM
redsidriver's Avatar
so basically he needs to be a 95 obd2 teg?
Old Jun 2, 2009 | 01:20 AM
str8drift's Avatar
yea is that true? will i have to be a 95obd2 teg?
Old Jun 2, 2009 | 06:45 AM
440lsd's Avatar
New User
I didn't think that you could bar a car if you swapped in an older motor. From what i've seen eh motor needs to be newer then the car or at least the same year.
Old Jun 2, 2009 | 07:02 AM
TGIJOSEPH's Avatar
so I have a full 2000 b18b LS swap...If i put this swap into a obd1 car like a 94-95 teg, or 92-95 hatch ...will i be able to BAR?
Old Jun 2, 2009 | 07:19 AM
440lsd's Avatar
New User
well thats what happens when you post to early in the morning
Old Jun 3, 2009 | 01:46 AM
Infamax's Avatar
Yes, you have to be fully converted to obd2 in order to bar an obd2 engine into an obd1 car.
brendan427
Oct 16, 2012 10:30 PM
hazard_one
Jul 19, 2005 12:31 PM
shadykit
Sep 19, 2004 04:02 PM
