please help me...motor is lown on my sub and speaker.
Old May 31, 2009 | 08:05 PM
Dead CIVIC's Avatar
Veteran: Army
Default please help me...motor is lown on my sub and speaker.
ok i havea kicker to a alpine digital amp.
and a performance technique to two pioneers.
it was perfect with the sub and the back speaker hooked up to my 4 chan...(i was lazy to run the fron RCAs) no i decided to run the fron RCAs to hear good all arround. so i ran the wires adn hooked up the RCAs...engine noise...hassle with it for a minute. then i said fk it.
so i left it alone. then i decided to hook up the fronts to the rear out put witch was working fine. to i do so and when i hooked up the right one. i heard a lound squeeeel sound. and then just noise all arround. WTH? i took out the speaker on the driver side witch is the one that made it do that. and i think the wire was touching the metal door. what could this have caused?
Old Jun 1, 2009 | 04:34 PM
ef 991red's Avatar
Default Re: please help me...motor is lown on my sub and speaker.
well first you might want to be a lil bit more specific and write as a normal person no like your texting! and the only thing that could've caused that is when you hooked it all and pinched the wire or maybe is just too old! i'd say run new wires and that will fix your problem is always better run new wires with aftermarket speakers since oem wire is not oxygen free and is the major cause of loss of sound fidelity.good luck!
Old Jun 2, 2009 | 12:01 PM
twentyhurtz's Avatar
i'm not even sure if i understand the problem....? i don't understand grunt...
Feli
Audio / Security / Video
Feb 28, 2010 06:03 PM
Bobaroo
Jul 1, 2007 09:32 AM
rockin_remz
May 27, 2006 07:30 PM
projektvtec
Sep 8, 2005 07:18 AM
lotas
Aug 20, 2004 10:21 AM
