Remove Intake pipe from throttle body. Should engine die?
I'm trying to trouble shoot a rough idle problem (not my car). When i remove the intake piping fron the throttle body should the engine die? I don't think it should, but maybe i'm wrong. I also assume the throttle plate should be totally closed during idle right?
Escobar. No its not an accord. Its a 95 Mazda Protege but i thought i would ask here since good technical people are on this forum.
The car has a very rough idle but runs fine at other engine speeds. Tonight i'm going to spray some throttle body cleaner to look for vacumm leaks but last night with the engine idleing (rough of course) i removed the intake pipe to look inside the throttle body and the engine shut off. It wouldnt' start again till i put the pipe back on. What does that mean?
If it's dying by simply takin off the intake pipe.. i'm not really sure.
98IntegraLSNonVtec
Dec 28, 2005 11:17 AM
Audi2Honda
Aug 19, 2002 06:58 PM
