NOT building fuel PRESSURE, HELP
Old May 30, 2009 | 10:33 PM
WheaMyRyceGo's Avatar
Default NOT building fuel PRESSURE, HELP
I just had the car rebuilt with a brand new block. Injectors, fuel filter, and fuel pump were also replaced.
I can't figure out why I am NOT building fuel pressure. When I crack the nut loose on the fuel filter, only a little bit of fuel comes out.
I can hear the walbro fuel pump on, so that can't be the problem...
Fuel filter was a possibility but it was replaced.
What else can the problem be?
Old May 31, 2009 | 06:25 AM
mtber's Avatar
Default Re: NOT building fuel PRESSURE, HELP
Chances are the fuel pump was improperly installed or you have the wrong pump which sets the fuel pickup sock higher then it is supposed to be.
Take the assembly apart & examine it.
Old May 31, 2009 | 07:25 AM
civicsiboyboy's Avatar
could be the fuel pump or the fuel pressure regulator
Old May 31, 2009 | 08:54 AM
When I was on the dyno, the tuners friend dropped by and we took his FPR and swapped it with mine and we still had the same problem.
I have taken out the fuel pump out 2 times now to examine it. I don't see how it can be improperly installed because it is pretty easy. 2 Wire clips and a couple coupling clips. Ill probably take it out again today and see what part number is written on the fuel pump.
Is there a good chance that its the injectors? Can I test this by pulling out the clip and if the sound of the motor doesn't change, its the injectors?
Old May 31, 2009 | 04:33 PM
slo blue's Avatar
have you had this problem ever since you reinstalled the engine?
Old May 31, 2009 | 04:37 PM
skippygsr's Avatar
did you check all the fuel lines..like if they are pinched any where
cyrix12
32
Oct 24, 2006 07:42 AM
iNetForce
Nov 13, 2005 08:27 PM
sway892
Jun 4, 2004 04:46 PM
Lei Siew Long
Jan 2, 2003 07:41 PM
E Swift
Nov 4, 2002 07:55 PM
