Just got 5 ABS codes!
Hi all,
My ABS/SRS connection was unplugged from the back of my cluster. I had no idea until I took it off today. I retrieved my ABS codes and got this:
11 - wheel sensor (open/short to body ground/short to power) FR
16 - wheel sensor (electrical noise/intermittent interruption) RR
54 - fail-safe relay
61 - ignition voltage
81 - central processing unti (CPU)
(taken from Integra FAQ 98+ ABS Codes)
What should I check for codes 11 & 16? I'm not sure what the descriptions mean. Also, code 61 - "ignition voltage," where would I check the voltage? Please help me if you've done some of this stuff before. Thanks
possible abs ecu failure. unless some idiot removed parts of it and left others an intact system almost never fails to that extent, code 81 is your real clue to the abs ecu failure.
granted the integra abs system isn't really the greatest. those of you who have driven a porsche or even a corvette know what i mean here. it's like two different worlds of abs. still, having it should make you a little faster around the track since you don't have to worry about tire sliding when you plow the pedal.
