lug nut questions
Old Aug 19, 2002 | 02:45 PM
94civicx's Avatar
New User
Default lug nut questions
Is it perfectly fine to tighten the lug nuts after removing the tire without a torque wrench?
Old Aug 19, 2002 | 03:35 PM
deepnite's Avatar
Default Re: lug nut questions (94civicx)
u dont want to tighen it so much that ull snap a lug off or so loose that ull loose a wheel either ..so if ur lucky or can guess pretty good do it urself and save a a few bucks
Old Aug 20, 2002 | 02:12 AM
m3tedd's Avatar
Well if you want to keep your alignment strait you should. Hondas need about 80lbs of torque. You can buy a cheap Torque wrench for like 20bucks if your still too cheap get an 80 pounder to sit on your wrench. If you dont put on your lugs right alot of things can happen so its up to you to take the risk. You can't always be sure that they are all on right.
Old Aug 20, 2002 | 08:36 AM
cre18's Avatar
Default Re: lug nut questions (m3tedd)
not torqueing (sp) your lug nuts down equally can cause your rotors to become warped and at high speed braking you will feel the tires shake through the steering wheel and brake pedal.
mnbvcxz358
Jul 20, 2010 10:56 AM
bsmith100
Sep 23, 2009 01:21 PM
THEUSED
Aug 31, 2009 02:58 PM
nsxtasy
Aug 27, 2008 10:45 AM
DC_andrew
15
Feb 18, 2004 06:45 PM
