compression test help
Old May 28, 2009 | 03:17 PM
xJDMCx's Avatar
Default compression test help
so i want to preform a compression test but before i do i need to know what fuses to pull and any other precautions i should take because i need my car to start after
Old May 28, 2009 | 03:23 PM
Former User's Avatar
Default Re: compression test help
Click here.
Old May 28, 2009 | 03:25 PM
civic_driver's Avatar
Pull the fuel pump fuse and disconnect the coil wire from the coil.
Edit: Or pulling the ECU fuse as Ron suggested which disables both fuel and spark.
Old May 28, 2009 | 03:29 PM
xJDMCx's Avatar
which is the ecu fuse?
Old May 28, 2009 | 03:55 PM
It should be under the hood. On 92-95 civics it says "ECU" on the fuse. On 96-00 civics, it says "Back Up" on the fuse.
Old May 28, 2009 | 04:42 PM
xJDMCx's Avatar
i ran my test and come out with. . 120. 118. 115. 120.. are those decent numbers? shouldn't i be at around 180 190 psi? should i preform a leak down as well?
Old May 28, 2009 | 04:59 PM
Try putting like a teaspoon of oil in there before you do the compression test and see if you get different numbers. Is your car running well? You might not be doing something right.
Old May 28, 2009 | 05:04 PM
xJDMCx's Avatar
alright ill try that.. i drove the car about 45 mins before i ran the test so the motor was semi cool..
my new numbers are 130 130 120 130.. are those too low?
Old May 29, 2009 | 06:10 PM
For my D16Y7 which is from a 99 civic, the minimum is 135psi. I don't know what it is exactly for your motor but it should be around 130. Those numbers seem kind of low though.
What kind of car/motor do you have and how many miles on it?
polishedturd
Feb 20, 2008 03:22 AM
cvclover
Feb 25, 2007 06:43 AM
watsvtecEK
Dec 12, 2005 07:28 AM
SexyH22
May 1, 2005 10:45 AM
jbiggsSE
Jul 16, 2004 06:41 AM
