Antenna question?
Old May 28, 2009 | 12:56 PM
96CIVICEX's Avatar
Default Antenna question?
I have a 97 ex. I want the antenna to always be in the down position, instead of extending because I think it gives the car a cleaner look. I know I can buy an antenna block off, but I want to keep the stock antenna so that i get reception on my radio. Is there a wire i can cut to keep it from extending, and still get reception on my radio, or how should I go about this?
Old May 28, 2009 | 01:01 PM
civic_driver's Avatar
Default Re: Antenna question?
There's probably a motor that extends the antenna. You have to cut the wire that power the motor.
Although, I think what you're doing is a bad idea. For good reception, you need the antenna to extend. That's why it's there. Of course, there are always people who prefer aesthetics over function.
Old May 28, 2009 | 01:07 PM
96CIVICEX's Avatar
Well, is the antenna suppose to retract once the car is off, or once the radio is off, cause mine is extended at all time? Is there a way to make it retract? Its the fact that its constantly extended that bothers me
Old May 28, 2009 | 01:12 PM
Hmm, can't answer that question. My civics didn't have a power antenna so I wouldn't know. Hopefully someone can answer your question.
Are you sure you have a power antenna and not a manual one?
Old May 28, 2009 | 01:15 PM
hard_boiled_EG's Avatar
mines was like that...i just broke it...
Old May 28, 2009 | 01:18 PM
Don't brake it. If it doesn't retract, the motor or the wiring is bad. Fix it if you can.
Old May 28, 2009 | 01:32 PM
98civdx's Avatar
Master Detailer
yes it should on the ex. should go up when radio is on and down when its off.
my dx isnt and i hate it.
check the wiring, maybe the motors fried
Old May 28, 2009 | 01:54 PM
96CIVICEX's Avatar
is there a guide/walk threw for getting to the motor?
Old May 28, 2009 | 02:13 PM
thumper64's Avatar
How about an antenna block off (part number 39152-SR2-A00) and a hidden antenna? I just bought two off fleabay and they pick up stations my stock one can't.
Old May 28, 2009 | 02:26 PM
96CIVICEX's Avatar
That sounds like a good idea, but how much does all that cost and how hard is it to install the hidden antenna? And is there a walk threw?
BG-Teg
Apr 25, 2007 05:44 AM
technine
Audio / Security / Video
Jul 20, 2005 11:36 AM
mist sITR
Mar 23, 2004 01:36 PM
geminis2k
Jan 30, 2004 09:10 AM
.Ryan
Jan 23, 2003 06:23 PM
