omfg still bogging
Old May 27, 2009 | 05:07 PM
lilshady6796's Avatar
Default omfg still bogging
okay so i changed my valve seals well my car is still smoking like a son of a btch and boggs like a **** can some one please tell me why it boggs atleast i dont care aboutthe smoke right now thats not eating my gas like the bogging does??please any one
Old May 27, 2009 | 05:18 PM
Default Re: omfg still bogging
any one please?
Old May 27, 2009 | 06:05 PM
wazooz2424@aol.com's Avatar
its hard to say without really looking at it and knowing the complete history/symptoms. if it bogs at high speed or under hard acceleration, i would replace the fuel filter first. did you recently run the gas tank empty or near empty? if so, that can stir up the sediment on the bottom of the tank which then travels to the fuel filter.
Old May 27, 2009 | 06:07 PM
Former User's Avatar
Is the CEL ON?
I assume by the poor gas mileage that the smoke is black (fuel) rather than blue (oil).
Measure your fuel pressure and check whether a fuel injector(s) is stuck open.
In addition, do you have a thermostat installed? Is the temperature sensor working? Is the ignition timing set to spec? Do you have an exhaust leak around the O2 sensor?
Old May 27, 2009 | 06:45 PM
no holes in exhaust, doubt its fuel injecters or fuilter, but ill check anyways, what about valves??
Old May 27, 2009 | 06:48 PM
Originally Posted by lilshady6796
...what about valves??
Valve clearance/lash out of spec is another possibility.
Old May 27, 2009 | 06:49 PM
thats all to speck, bent or burnt maybee
Old May 27, 2009 | 06:52 PM
Are you burning oil? Or just too much fuel?
Carbon build up might be cleaned up with some Seafoam.
If you think that some valves may be bent, compression test the cylinders.
Old May 27, 2009 | 06:59 PM
burning oil real bad clouds of the ****, and i did a test from pully side to dizzy...180 195180 195
Old May 27, 2009 | 07:02 PM
Seems like something went very wrong when you installed the new valve seals. Better have another look at them.
Old May 27, 2009 | 07:03 PM
idk how its been doing it even before i changed them, could they cause my car to bog real bad tho??
Old May 27, 2009 | 07:06 PM
You're losing and burning a lot of oil, right? Solve that important problem first and then go from there.
Old May 27, 2009 | 07:07 PM
pcv valve maybee??
Old May 27, 2009 | 07:11 PM
Is the PCV valve hose filled with oil?
Old May 27, 2009 | 07:13 PM
not sure
Old May 27, 2009 | 07:19 PM
not sure
Easy to check. Also look inside the IM to see if there is free standing oil.
Old May 27, 2009 | 07:23 PM
nothin no oil in line or the hole
Old May 27, 2009 | 07:26 PM
Your cylinder compressions are good, indicating that the rings and head gasket are fine, so you're back to bad valve seals.
Old May 27, 2009 | 07:29 PM
oka, well i know i just installed them today but... they fit kinda loose like i could just take them off with ease no problem and with the old ones i had to try and pry alot was pretty hard to take them off..this mean anything?
Old May 27, 2009 | 07:31 PM
What year/engine?
Old May 27, 2009 | 07:35 PM
95 civic, d15 block z6 head ran great for 4 months
Old May 27, 2009 | 07:39 PM
Old May 27, 2009 | 07:44 PM
??? i did it like that
Old May 27, 2009 | 07:48 PM
o thats ugly i didnt know the where color coded like that, whats happens if i mixed them up, and do i have to use a seal installer cuz i just set them on the valve where they where suppsoed to be??
Novz
Jan 7, 2011 11:47 AM
pli
Honda S2000
16
Oct 22, 2008 02:20 PM
dirrtybirdy
Dec 4, 2007 06:09 PM
bitz95civ
Dec 30, 2005 02:38 PM
JBBNJ609
May 14, 2004 11:53 AM
