92-95 civic hb rear wiper motor question
Old May 27, 2009 | 11:18 AM
wazooz2424@aol.com's Avatar
Default 92-95 civic hb rear wiper motor question
I just picked up a 95 si hb. the rear wiper motor comes on, but doesnt rotate. I took apart the motor (removed rear backing plate) and discovered the following.
if you havent seen the inside of one of these motors, I will try to describe it as best as i can....
there are 3 "gears" inside. gear 1 (plastic, largest gear) spins with the switch being turned on. this gear has a metal peg on it.
gear 2 is a medium sized metal gear which SHOULD be attached to gear1. gear1 spins with the motor, which in turn, spins gear2 which is joined to gear3. gear3 connects through the hatch window and to the wiper arm.
whatever attaches gear1 to gear2 is missing. what i am hoping for is someone here to either know what attaches them, or someone that has a motor laying around that can take it apart and either send me pics or tell me whats there. thanks for the help and sorry for the long post.
Old May 28, 2009 | 05:24 PM
KRZRICAN's Avatar
Default Re: 92-95 civic hb rear wiper motor question
I have the same problem..i also missing something in the wiper motor..seams like there suppose to be plate or arm to make the wiper move..let me know.
Old May 28, 2009 | 05:35 PM
BryanM.'s Avatar
Resident Gearhead
I have one, I am not going to use it and I can take it appart tommorow.
Check this thread in 24 hrs, I will try my hardest to get pics for you.
mcvtec
civic_driver's Avatar
Look on Majestic Honda if they have the part you need. If they don't, you will have to replace the whole motor.
Old May 29, 2009 | 07:12 AM
mcvtec
thanks!
Old May 29, 2009 | 08:29 AM
SpeedDemon09's Avatar
it may not be the motor. it may be that the nut on the outside of the wiper is loose. just take the small black plastic cover off and tighten the nut, should be an 8/9 mm. dont over tighten though, it will break the glass
Old May 29, 2009 | 08:35 AM
its not a malfunction with anything, its a missing piece inside. nothing to do with the nut that holds the arm down.
Old May 29, 2009 | 08:36 AM
hmm i see. then yeah try finding a piece at the junk yard. just take the whole motor assembly. i had the same problem as you but mine turned out to be that nut, just thought i would suggest it
Old May 29, 2009 | 08:38 AM
no problem. local yard doesnt have any in stock. buying a complete motor off craigslist today. i will post the answer to the mystery later. looks like at least one other person has the same issue, so maybe more do, as well.
Old May 29, 2009 | 08:40 AM
yep, well good luck with it, be sure to get pics of how it goes
Old May 29, 2009 | 01:37 PM
BryanM.'s Avatar
Resident Gearhead
Here ya go.
Old May 31, 2009 | 05:50 AM
KRZRICAN's Avatar
THATS THE PIECE I NEED......ALSO the previous owner bolted on the wiper in a higher level(wiper).if i get the piece my wiper will turn over the glass unto the hatch.i took off the nut and the wiper is hard to take off.dont want to break the glass...what can i use to take it off?
jcorange
Oct 2, 2017 09:55 AM
TomCat39
18
Oct 9, 2015 05:43 PM
mike:
10
Jul 3, 2014 08:21 PM
archie77
Nov 23, 2013 12:21 AM
timrichter9
Jun 23, 2011 12:06 PM
