Horn not working on my 95 Hatch, need to know what to look for.
Old May 27, 2009 | 06:40 AM
Buktheng's Avatar
Default Horn not working on my 95 Hatch, need to know what to look for.
I bought a 95 hatch that had an aftermarket steering wheel on it and I'm guessing the guy put the oem steering wheel back into it but didn't hook up the horn. I need to get the horn working so I can pass inspection.
What exactly should I be looking for when I take off the steering wheel? Blown fuse? Wiring not connected right? If you guys could help me figure it out, that would be great. Thanks!
Old May 27, 2009 | 06:50 AM
KeLoko28's Avatar
New User
Default Re: Horn not working on my 95 Hatch, need to know what to look for.
First of all check the horn fuses it might be as simply as that.....
Old May 27, 2009 | 06:52 AM
marvinp8700's Avatar
yellow srs harness
check to see if it's good then check fuses and what not
Old May 27, 2009 | 06:57 AM
Buktheng's Avatar
The fuse are in the fuse box next to the battery?
Old May 27, 2009 | 07:38 AM
KeLoko28's Avatar
New User
in can be under the hood or by the pedals ethier one check ur fuse driagramm on both an che the fuse if it blown and just replace with the same number of amps
Old May 29, 2009 | 06:53 AM
Buktheng's Avatar
Alright I just check the fuse, it was next to the battery. Fused looked perfectly fine. What else should I look for now?
Old May 29, 2009 | 08:28 AM
fhukingviet's Avatar
for a temporary use, you can just make a switch or button for the horn for now, switches at walmart or something anywhere... cut horn wires, horn positive to switch and battery positive to switch and ground your horn, when you press on switch... it will horn
Old May 29, 2009 | 08:40 AM
wazooz2424@aol.com's Avatar
remove the airbag and see if the horn is connected. it will be a single black wire near the top of the steering wheel. search on here for the service manuals, it will break down troubleshooting and removing the airbag.
spens 91 Ef
May 13, 2009 04:18 PM
Tuesdaynightfever
Apr 5, 2005 07:34 PM
hookedonvtec
Feb 8, 2005 05:30 PM
XxSOHCDriVerxX
Oct 1, 2003 06:24 AM
RR71NC
Sep 11, 2003 12:59 PM
