Horn not working on my 95 Hatch, need to know what to look for.
I bought a 95 hatch that had an aftermarket steering wheel on it and I'm guessing the guy put the oem steering wheel back into it but didn't hook up the horn. I need to get the horn working so I can pass inspection.
What exactly should I be looking for when I take off the steering wheel? Blown fuse? Wiring not connected right? If you guys could help me figure it out, that would be great. Thanks!
Re: Horn not working on my 95 Hatch, need to know what to look for.
in can be under the hood or by the pedals ethier one check ur fuse driagramm on both an che the fuse if it blown and just replace with the same number of amps
Alright I just check the fuse, it was next to the battery. Fused looked perfectly fine. What else should I look for now?
for a temporary use, you can just make a switch or button for the horn for now, switches at walmart or something anywhere... cut horn wires, horn positive to switch and battery positive to switch and ground your horn, when you press on switch... it will horn
remove the airbag and see if the horn is connected. it will be a single black wire near the top of the steering wheel. search on here for the service manuals, it will break down troubleshooting and removing the airbag.
XxSOHCDriVerxX
10-01-2003 06:24 AM
