*** what causes my tranny to pop out of 5th gear while on HWY?
Old May 27, 2009 | 05:11 AM
Charlie Moua's Avatar
Default *** what causes my tranny to pop out of 5th gear while on HWY?
My kid brothers DA keeps poping out of 5th gear while on the hwy.
His clutch still grabs very well.
At first I thought it was his short shifter, so I replaced it with OEM shifter... but still has the same problem....
What do you think it is?
Old May 27, 2009 | 05:25 AM
SubiMan's Avatar
Default Re: *** what causes my tranny to pop out of 5th gear while on HWY?
it's most likely the synchros in fifth.
Old May 27, 2009 | 06:24 AM
danyal2's Avatar
New User
Check your tranny fluid, mine popped out when there was a leak.
Old May 27, 2009 | 06:48 AM
ApexiChild's Avatar
Good info...
But if it's pops out of 5th gear why doesn't it pop out of all of the other gears 1-2-3-4?
How much fluids does a LS tranny take? .... 2 quarts...2.5 qarts?
Old May 27, 2009 | 07:04 AM
mouab18c1's Avatar
syncrho
Old May 27, 2009 | 10:39 AM
hum... I would of never thought that, because most of the cars that have sycro issues are hard to shift in/out of....
His tranny still shifts like butter....
Do you think i should try the GM syncromesh stuff.... hehe
Old May 27, 2009 | 10:42 AM
steveo135's Avatar
i suggest seeing if you can find another tranny for cheap
Old May 27, 2009 | 10:43 AM
rebar71's Avatar
That's what I'm using.
Check the fluid level. I've never had this particular problem, but from what I've read, it usually indicates low fluid.
Old May 27, 2009 | 06:22 PM
Thanks i'll try adding more MTF first....
Old May 27, 2009 | 08:50 PM
jlow125's Avatar
100% it is low on fluid. I had the same problem last year.
Old Jul 28, 2009 | 04:59 PM
JdmBreezeKb's Avatar
im having the same problem with my tranny! i hope its the fluid. i just got that thing off hmo
Old Jul 28, 2009 | 05:51 PM
Jintegragsr97's Avatar
Most likely the tranny fluid is low. Happened to lots of people I know.
polishedturd
Nov 29, 2007 05:59 AM
JDM-EJ698
Sep 1, 2006 03:26 PM
IEATLINT
Sep 10, 2004 12:52 PM
SimbaDogg
Feb 22, 2004 10:11 AM
HeikDiesel
Nov 19, 2002 11:53 AM
