installed jdm gsr into 99 civic hatch
Old May 26, 2009 | 06:43 PM
rafaek9k24's Avatar
Default installed jdm gsr into 99 civic hatch
i just installed a jdm gsr into a 99 hatch the gsr has a skunk 2 manifold i was wondering what throttle cable and bracket i need to use
Old May 26, 2009 | 06:50 PM
Michael1989's Avatar
Default Re: installed jdm gsr into 99 civic hatch
You need a Type r throttle cable and type r bracket
Old May 26, 2009 | 07:18 PM
rafaek9k24's Avatar
would i need to modify anything else or that just be it ?
Old May 26, 2009 | 07:35 PM
No modding just take out old throttle cable and put in type r cable then bolt up bracket to intake manifold and tighten the cable to give you right pedal pressure.
Old May 26, 2009 | 11:23 PM
VRD^sam's Avatar
Are you still using the GSR throttle body?
Old May 26, 2009 | 11:35 PM
R666_EK's Avatar
x2
You will also need a new tb pulley. Just about any non gsr pulley will work. LS, type r, most civics etc.
Old May 28, 2009 | 02:08 PM
rafaek9k24's Avatar
NO THE THROTTLE BODY AFTER MARKET TWO
Old May 28, 2009 | 02:10 PM
gsbartender's Avatar
I highly recommend upgrading the fuel pump aswell.. I had problems when I did my swap.. engine was running lean.. look into it.
Old May 28, 2009 | 02:13 PM
rafaek9k24's Avatar
LOL YA I LEARNED MY LESSON WIT MY FULLY BUILT SINGLE
Old May 28, 2009 | 04:05 PM
R666_EK's Avatar
Fuel pump should be fine for a GSR swap. Mine is stock.
theEG6
Mar 3, 2014 04:50 AM
highliner82
Dec 1, 2010 05:35 PM
ramswood2000
Sep 15, 2010 07:44 PM
TurboIntegra
Jul 21, 2006 03:25 AM
bracket 4 life
Dec 21, 2004 08:20 AM
