Benen front sturt bar install
Old May 26, 2009 | 04:35 PM
ecko_3420's Avatar
Default Benen front sturt bar install
I just got a benen tripod front strut bar and would like to know what size hole to drill and nuts and bolts to use? Ive searched and none of the thread specified the size to use.. Thanks...I have a 97 civic hatchback...
Old May 26, 2009 | 06:05 PM
ecko_3420's Avatar
Default Re: Benen front sturt bar install
bump
Old May 26, 2009 | 06:51 PM
mynameizstitch's Avatar
should already have holes there. cuz on the eg6 there are holes there already and you will need a size 10 bolt. just take one of the bolt from your hood and go to a hardware store and buy the same bolt.
Old May 26, 2009 | 06:52 PM
Meoshe's Avatar
Take it to the hardware store with you and browse their grade 8 bins for whatever fits. Then just use a drill bit that is right around the same size.
to stitch: 96-00 civics don't have the holes like earlier models.
Old May 26, 2009 | 08:41 PM
ecko_3420's Avatar
grade 8? i read about that earlier...is there really a dif? how long should the bolts be?
Old May 27, 2009 | 08:48 AM
Meoshe's Avatar
There is a difference in strength, I would say 1 inch is fine.
Old May 27, 2009 | 09:57 AM
STOCK_SOHC_DX's Avatar
What? Carbing bar bolted to my fire wall of my EK, I just had to take out the black plastic plugs.
Old May 27, 2009 | 01:05 PM
Meoshe's Avatar
Yeah that's because it mounts to the tophat studs. Note: I think he is talking about the mounts at the shock tower. The benen mounts to the top of the shock towers like the ITR/CTR/SI/GSR ones.
Old May 27, 2009 | 04:03 PM
Oh that one, I remember I used the biggest ones that could fit the Mugen bar grade 8. On my friends car that we did wire tuck we got a body shop to actually order the whole SI shoulder and remove and replace that was gangster.
Old May 27, 2009 | 11:42 PM
TheJGB3's Avatar
Yes 'grade 8' hardware is for automotive applications (harder/stronger steel).
Old May 28, 2009 | 12:13 AM
taggart_lumpy's Avatar
watch how long the bolts are though
depending on how low you are they may hit you front upper control arm
Old May 28, 2009 | 12:43 AM
hOnda_hiEn's Avatar
stick the bolts up from under.. LoL..
Old May 28, 2009 | 06:04 AM
sanegb16's Avatar
thats what i do haha
Old May 28, 2009 | 06:37 AM
rick_rabies's Avatar
I'm not Rick!
...weld it
Jaylom
Aug 16, 2011 07:22 AM
mynameizstitch
Mar 11, 2009 06:40 AM
nighthawkgsr
Sep 20, 2007 06:52 AM
92civeg
Jun 20, 2003 03:56 AM
