B18c5 ignition timming?
Old May 26, 2009 | 03:25 PM
jerzey908's Avatar
Default B18c5 ignition timming?
Ok well i had to buy a new distributor for my itr. All i want to no is how far advance can i set my timming. I also have adjustable cam gears that are set at 0 degress if that means any thing. can i adjust them to?
Old May 26, 2009 | 06:43 PM
HFP_racing's Avatar
Default Re: B18c5 ignition timming?
umm since im the only one tht has answer here..ok since u got a new dizzy just get a timing gun a set ur ignition timing to stock i believe is 14 u can set at 16 if u want. and on the cam gears i would leave on zero an let a tuner do tht so u can get some hp out ur car is it stock.
Old May 26, 2009 | 09:19 PM
racebum's Avatar
leave the cam gears alone. install the dizzy in the middle. start the car with that jumper under the passenger dash jumped. let the car warm up. when it's at operating temp and the idle goes down get your gun and you should have 3 dots pop up when you move the distributor around., the one on the end when you move toward the firewall is 18deg, the middle is 16 deg, pick one of those two. just make sure you're at 750-800rpm when you time it. the jumper should help make sure this stays stable.
Old May 27, 2009 | 05:18 AM
vxhatched's Avatar
16 degrees is stock. Adjusting the cam gears will put your powerband in a different spot so I would leave it a the TDC mark. maybe advance the timing 2 degrees at the distributor, 18. If not ,leave the distributor at TDC and do 1 mark advanced on the intake cam gear which will be 2 degrees advanced, and 2 marks back toward the radiator on the exhaust which will be 4 degrees retarded, which that usually works good. But every car is different. Dyno is the best way to know.
Old May 27, 2009 | 02:42 PM
jerzey908's Avatar
thanks for the help. I will be use a advance timing light with the dail on it. so i will set the dail on the light to 18 and then move the dizzy intill it read zero on the crank pully when shining the timing light. Is that correct of wrong. SORRY first time using a timing light.
Old May 27, 2009 | 02:44 PM
jerzey908's Avatar
by moving the cam gears will i get alittle more power if i do it that way. or should i just do it by the dizzy?
D3vin
Dec 31, 2010 04:24 PM
95_Civic_4dr
Dec 19, 2010 08:28 PM
LSVTEC 91 Civic
Aug 31, 2004 06:35 PM
lsvtec101
Mar 21, 2003 03:31 PM
Jockobo
Jan 23, 2003 03:48 PM
