A6 Swap info
Old May 26, 2009 | 02:33 PM
1990JDMCRX's Avatar
Default A6 Swap info
im swaping an a6 in and i was wondering what all i need/need to do for it to go right in?...can i use my current ECU, Harness, mounts, clutch, tranny?
Old May 28, 2009 | 05:49 AM
1990JDMCRX's Avatar
Default Re: A6 Swap info
bump for info
Old May 28, 2009 | 06:05 AM
rick_rabies's Avatar
I'm not Rick!
what the frick is an a6? the v6 stuff?
Old May 28, 2009 | 06:12 AM
marvinp8700's Avatar
might help if you would tell us what car you are swapping it into
Old May 28, 2009 | 06:38 AM
89s1's Avatar
*in from 88-91 Civic/CRX forum*
Stop stealing our a6's
Old May 28, 2009 | 07:22 AM
DCRB's Avatar
d16a6 - 88-91 1.6l obd0 motor non vtec. used in the crx/civic si's, the ex sedans, and the rt4wd wagons.
Old May 28, 2009 | 03:25 PM
1990JDMCRX's Avatar
sorry guys...i have a 92 honda civic hatchback CX, im buying a D16a6 block, and was told i might need another mount...i was also wondering if i could you my current: ECU, Mounts, Tranny, Clutch, Wiring Harness, and basicly all my current parts, like O2 sensor and stuff like that...Thanks
Old May 28, 2009 | 04:26 PM
got00rice's Avatar
yes if you're using your current hydralic tranny then everything should be fine.. but you dizzy plug and some other small plug would need to be replace. again the dizzy you can switch to a obd1 dizzy or else if using the a6 dizzy then you'll need to convert from obd0-obd1
Old May 28, 2009 | 07:07 PM
1990JDMCRX's Avatar
so get a d16a6 dizzy and i can use everything else?
Old May 29, 2009 | 12:56 PM
1990JDMCRX's Avatar
bump for info
crappyshifting
Aug 19, 2013 11:49 PM
masonracing
Jan 4, 2013 05:30 PM
jdmeg21
Sep 30, 2009 11:22 AM
ATL-EF squad
May 7, 2008 09:15 PM
SteveeeO
Mar 11, 2003 05:04 PM
