A6 Swap info
A6 Swap info
im swaping an a6 in and i was wondering what all i need/need to do for it to go right in?...can i use my current ECU, Harness, mounts, clutch, tranny?
Re: A6 Swap info
sorry guys...i have a 92 honda civic hatchback CX, im buying a D16a6 block, and was told i might need another mount...i was also wondering if i could you my current: ECU, Mounts, Tranny, Clutch, Wiring Harness, and basicly all my current parts, like O2 sensor and stuff like that...Thanks
Re: A6 Swap info
yes if you're using your current hydralic tranny then everything should be fine.. but you dizzy plug and some other small plug would need to be replace. again the dizzy you can switch to a obd1 dizzy or else if using the a6 dizzy then you'll need to convert from obd0-obd1
jdmeg21
09-30-2009 11:22 AM
SteveeeO
03-11-2003 05:04 PM
