how can you tell when your motor mounts are bad?
Old May 26, 2009 | 07:16 AM
hondaon18's's Avatar
Default how can you tell when your motor mounts are bad?
i got a hatch with a b16 in it but i want to know is how or what noises do you hear so you can tell when your motor mounts go bad. i would like to know? i know beside movement what noises can it make to determine if its bad.
Old May 26, 2009 | 07:50 AM
1LowSol's Avatar
Default Re: how can you tell when your motor mounts are bad?
Should just be able to visually inspect them and determine. For example on mine, My Driver side lower motor mount was Blown out... I got under the car and looked and there was no rubber left inside the motor mount.
Old May 26, 2009 | 08:19 AM
goldfinger93030's Avatar
you should feel vibrations like crazy if they have gone bad
Old May 26, 2009 | 08:25 AM
stagen's Avatar
Or if they'r like mine the motor will hit the hood on hard shifts :/ New mounts are on their way tho.
But usually you can visually inspect them for cracks or missing rubber. Or if you've rcently develposed some really bad wheel hop. Also a problem of mine now.
Old May 26, 2009 | 08:28 AM
rick_rabies's Avatar
I'm not Rick!
your motor will fall out....it happens
Old May 26, 2009 | 09:07 AM
thurmondauto's Avatar
There are two ways a motor mount can really go bad,
1. Crack in the rubber
2. Damaged bolts ( *RARE* only happens to race cars, unless your pushing 1200 hp +)
I recently broke a motor mount and I will post pictures up of what you should look for!
Old May 26, 2009 | 09:18 AM
Thats a cracked motor mount I did not have the time to circle the crack but you should be able to see it.
Old May 26, 2009 | 10:31 AM
ok so on my when i go over speed bumps i here like on my pass side like hard hits and bad noise. at first i thought that is was my rack making the noise but i replaced that and i also replaced all my suspension but all that i got left is the mounts. that is what i think could be making noise cause it makes like real loud clunks noises
Old May 26, 2009 | 10:34 AM
Adankid's Avatar
its your transmission bracket.
Old May 27, 2009 | 09:59 AM
the one that go's to the side of the trans or the top one are you sure. how else can you tell?
95accordian
Feb 2, 2014 10:48 PM
civicsi18
Oct 27, 2008 12:05 PM
manyakiexpi
May 17, 2006 09:56 PM
Flamenco-T
Nov 29, 2001 10:55 PM
