Quick turbo inlet/outlet question
/Hey guys, a very quick question on the t3/t4 turbonetics i just purchased, what is this inlet or outlet used for (circled in blue)??
The turbo drain is marked and the turbo oil feed is on the other side but I just cannot figure out what these two threaded holes are for...(there is another one on the other side).
Thanks in advanced.
Thanks in advanced.
if the turbo is journal bearing then most likely the oil can lubricate and cool the turbo sufficiently but running the water lines is required to keep the warranty in place.
if its ball bearing then the water lines will be needed to cool the turbo and maintain longevity.
slotec
May 22, 2005 06:13 PM
Civicman86
Jan 31, 2005 08:47 AM
