vtec pressure switch
Old May 24, 2009 | 09:14 PM
dave181's Avatar
Post vtec pressure switch
i have a 95 civic dx with a d15b p28 ecu i figured out the cel i was throwing was a 22 i replaced the pressure switch yesterday well lat night and guess what still throwing the the same cel so now whats wrong with the car im stump and i hope someone can help me out with mt problem
Old May 25, 2009 | 10:30 PM
dave181's Avatar
Default Re: vtec pressure switch
anyone
Old May 26, 2009 | 07:56 AM
delsolproblems's Avatar
Check the wires. Make sure they're connected correctly. Disconnect the round connector. Put key in ON position. Check the voltage between (blue/black wire?) and body ground- should be 12v. If not, check the (blue/black?) wire for breaks. Check voltage across the two terminals of the connector (blue/black & black wires?)- should be 12v. If not, check the black ground wire for breaks & proper grounding.
Old May 26, 2009 | 03:51 PM
dave181's Avatar
what do u meen breks im a noob at wireing lol thanks
Old May 26, 2009 | 10:22 PM
dave181's Avatar
bump
Old May 27, 2009 | 12:18 AM
aasarsak's Avatar
did you reset your ECU after you fixed it?
Old May 27, 2009 | 09:35 AM
Check for breaks means follow the wire and look for places where its plastic sheath has worn away or any other way the wire could be grounded, broken or disconnected. If the first wire doesnt show power when the multimeter is grounded, then that wire is not connected. If that wire shows power when the meter is grounded to the body ground but not when the meter is grounded to the second (ground) wire, then that second ground wire is not connected.
Old May 27, 2009 | 12:38 PM
dave181's Avatar
I disconnected and reconnected the battery. Is there any other way to reset it??
Old May 27, 2009 | 09:15 PM
aasarsak's Avatar
No. That should have done it. How soon after you start the car did the cel come on again?
Btw, never replace a part until you have properly diagnosed it
Old May 27, 2009 | 09:22 PM
dave181's Avatar
it shut off for like 2 seconds and came back on almost emediatly and its throwing the same cel 22 i got a multimeter but ive never used1 b4 so i dont kno how to operate it can u tell me how so i can chek it im off thursday so ima atemp to chek it out thanks n advance
Old May 27, 2009 | 09:53 PM
aasarsak's Avatar
it came back on after what? after you started it, or after you turned the key to run, or after you plugged your battery back in?
Old May 27, 2009 | 10:00 PM
dave181's Avatar
after i started the car up it came back on i wont go off for sh.t
Old May 27, 2009 | 10:39 PM
aasarsak's Avatar
well, if you have replaced the switch, checked all the wire leads, fuses, and grounds, and reset the ecu, there is nothing left to check.
Is it possible that you read the ecu code wrong?
Old May 27, 2009 | 10:59 PM
dave181's Avatar
2 long flashes and 2 short fast flashes thats the only code it throws i never chekd the wires cause i dont know how to use a multimeter
Old May 27, 2009 | 11:12 PM
aasarsak's Avatar
you don't need a multimiter. Just look to see if there are any cracks or breaks in the wire.
You might do a continuity test from the ECU to the switch.
Just read the manual that came with the multimiter.
All you have to do is set it to resistance (ohms) and touch one end to the pressure switch pin on the ecu and the other end to the line going to the switch.
If there is no resistance, then your problem is probably the wire grounding out somewhere in between.
Check all your grounds too: battery, chassis, and engine block. Make sure everything is clean and tight like a virgin *****.
Old May 28, 2009 | 04:44 PM
dave181's Avatar
ok i checkd the grounds that i could c and they semd ok and the wires were wrapd up prety good to c any breks and the wire at the conector to the switch had a hle but thats from me useing a test lite ima put electrical tape on it and then atempt the multimeter since ive neve used 1 b4 lol like a virgen pusc ha ha ha
Old May 28, 2009 | 04:50 PM
set the meter to the 20v setting, connect the red probe to the DC terminal and the black probe to the COM terminal. Test as previously described. Don't leave the meter on when you're not immediately using it.
Old May 28, 2009 | 04:54 PM
dave181's Avatar
ok witch one is the com terminal and witch one is the dc terminal so i dont mess this up and also if i get nothing what could b the problem
Old May 28, 2009 | 05:20 PM
It should say COM next to the ground plug on the meter. Connect the red probe to the hole that has what looks like VQ-mA next to it. Turn the dial (probably counter-clockwise) to the 20V setting next to a "V-" (with 3 dots under the straight line), NOT V~ (with 3 dots under the squiggly line) and test.
Old May 28, 2009 | 05:38 PM
dave181's Avatar
ok thank u and where do i put the black conector on the mulimeter at i just put it on the frame and ground it rite or do i put it on a ground thats hood up
Old May 28, 2009 | 08:58 PM
aasarsak's Avatar
maybe these will help
Old May 28, 2009 | 09:05 PM
aasarsak's Avatar
let me know if you can't read them. I can blow up the images for you if you want.
Old May 28, 2009 | 10:36 PM
dave181's Avatar
could u blow it a lil bit please i can reed some of it not all
Old May 28, 2009 | 10:39 PM
aasarsak's Avatar
which part?
Old May 28, 2009 | 10:46 PM
aasarsak's Avatar
here you go
